torque converter question
Old Mar 11, 2012 | 01:27 AM
aknight_sa's Avatar
i'm about to make an order for my 97 Lt1 Camaro with a 4L60E tranny, the plan is to go with:
  1. XFI™ Xtreme Fuel Injection, 280XFI HR13: Cam & Kit
  2. Rocker Arm Kits; Chevy (V8 262-400 '87-Later w/ OE Hydraulic Roller Cam) 1.6 Magnum Rockers & Magnum
  3. will be looking for a 383 kit later on
  4. will need a stall converter
i do need help with choosing the stall converter, the Cam's RPM range is 2000 to 6000, so i dont know which converter to get, shall i get a 2000rpm stall converter or go higher?
Old Mar 11, 2012 | 02:22 PM
96capricemgr's Avatar
Re: torque converter question
The cam is too big, comp's rpm ranges are wrong with a shelf wide LSA cam you are probably going to want to keep the duration closer to mid 220s on the intake.
I certainly would NOT buy that "kit" either.
On the stall even with a bolton daily driver most folks go 3200 or so in a 9.5" converter, not cheap junk like B&M or TCI talking Edge, Yank Vigilante.
Then you are talking a "383 kit" but have not mentioned HEADS which are the most important part. Displacement does NOT add meaningful power unless you have the heads/cam to feed it. Ported stockers can be great but as cast stock heads on a 383 is a really bad idea that is done way too often.
My advise is settle down don't buy anything yet and start looking at results and what other's did to get those results
Old Mar 11, 2012 | 11:30 PM
aknight_sa's Avatar
i didnt mention the heads, but i will be having them ported..
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
ChrisFrez
Feb 15, 2015 07:49 AM
Collector Car
Dec 17, 2014 01:12 PM
squarehead
Nov 21, 2014 08:02 PM
RedLineRev
Jan 23, 2003 03:51 PM
