Torque converter
Old Sep 14, 2003 | 05:45 PM
tomt1986's Avatar
Unhappy Torque converter
Hey guys this is my first post to the board. I have a problem with my torque converter. i just installed a vigilante torque converter in my 94 z28 with lt1 and 4l60e trans. I was running 13.4s before the change but after i changed to the vigilante my car is running 13.9's i have no idea what the hell happened. Thats the only thing that i change that would effect the way the car would run. Have any of you ever heard of this or have had it happen to you?
I think the car should have run a high 12 with the converter change?
Tom
Mods:
K&n cold air intake,1Le high flow bellow,flowmaster exhaust,CAt delete Pipe, edelbrock headers and y pipe,electric water pump,accel wires, BBk throttle body, Granatelli MAF, Be cool aluminum radiator,B&M trans cooler,aluminum drive shaft, Miller racing torque arm, LCAs Panhard rod, LCA relocation brackets, sub frame connectors,kyb adjustable shocks, Bigger sway bars front 34 mm 26 mm rear, Ford 9 inch rear with 3:70 gears and locker,shift kit, vigilante converter.
60 foot 1.87
1/4 mile 13.9 @98 mph "Something is wrong with the car big time"
Old Sep 14, 2003 | 06:14 PM
rskrause's Avatar
Moderator
You may want to try the "Drag Racing" forum with this question. If you post all the times and speeds as well as the conditions from the runs, that will help in the analasis of what happened.
Rich Krause
Old Sep 14, 2003 | 06:25 PM
WheelmanZ28's Avatar
What stall speed is ur Vigilante set at??
There is a good possibility that u could be over-stalled.
Old Sep 14, 2003 | 06:55 PM
tomt1986's Avatar
The stall is 2800 Rpm.
Tom
Old Sep 14, 2003 | 11:32 PM
Robert95z's Avatar
just out of curiousity, what were your 60's before the converter?
Old Sep 15, 2003 | 07:30 PM
tomt1986's Avatar
converter
2.0 flat before the swap 1.8 after the swap.
TOm
Old Sep 15, 2003 | 08:05 PM
Transamdriver's Avatar
Call them or email them, they will do everything in their power to help you. I didnt even have their converter and they still helped me out with a couple questions.
http://www.converter.com
Tel: (901)466-0267
info@converter.com
Old Sep 15, 2003 | 08:35 PM
tomt1986's Avatar
hi
i plan on calling tomorrow
thanks
Old Sep 15, 2003 | 08:39 PM
PoorMan's Avatar
Did u change you launch RPM. I don't go to the track much but can't you run the motor up to above 2000+rpm now without it moving. I have also heard that some people don't hold the brake but just punch it causing the convertor to "flash". Suppose to give good results.
Jeff D.
Old Sep 15, 2003 | 08:45 PM
tomt1986's Avatar
question
yeah i agree 200 rpm is the limit then the car moves or breaks the tires loose. i will try to flash the car next time i go.
thanks
tom
dboone2172
May 16, 2015 07:45 PM
QuickSilver02
Apr 7, 2015 11:12 AM
F550maranello2
Apr 1, 2015 11:10 AM
StansZ28
Feb 19, 2015 07:39 AM
veryslowfbody
Aug 22, 2002 04:31 PM
