torque arm instalation help
I have just bought a new torque arm with built in drive shaft loop. It was the last one in the store, so I got the display set. It didn't come with instructions. Though it looks pretty straight foward, I just want to make sure I don't mess anything up when I drill out the holes to mount the front part of the unit.
Any help would be very appreciated.
What brand is it? How does the front end attach to the car - to the stock location on the tranny tailshaft?.... to the stock "g-load" brace location?.... to some other location, like up in the tunnel sheet metal?
There are so many different kinds available, you need to tell us what brand it is. When you start talking about drilling holes, it would appear you have one that mounts up in the tunnel, since the first two types mentioned above do not need any holes drilled.
It does mount to the tunnel sheet metal. the drive shaft loop mounted to this piece. The torque arm slides on to a post that is also connected to this part. It has eleven bolts that need to be drilled for the bolts to mount it.
It seems pretty straight foward, but I just want to get a little feedback before I get started drilling a bunch of holes in my car.
