torque and antiseize
Old Jan 1, 2004 | 05:08 PM
BPS's Avatar
BPS
What is the general rule to follow in applying torques specifications when tightening a bolt that has antiseize on it?
Also would bolts with sealent or locktight be torqued to wet or dry specifications.
Most torque numbers assume dry treads - so when lubricated less torque is required to overcome friction. I did some research and advice ranges from 20% to 50% of dry spec.
What do you all do?
Jake Bialke
Sep 24, 2015 11:31 AM
MDZ28
11
Sep 24, 2015 09:15 AM
Bxlt1
Sep 17, 2015 08:31 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
realistyc
Jul 28, 2015 07:32 PM
