Timing Gear Cover Leaking
Old Jan 1, 2004 | 05:11 PM
Cahill93Z's Avatar
Just in the passed week my car started leaking oil, it used to leak zero. I found it was coming from the front of the engine, first thoughts were front mian seal, but after looking harder it's actually coming from the timing gear cover and runing down the front side of the motor. Has anyone ever had this problem? How hard is it to replace the Timing gear cover seal? thanks
Old Jan 1, 2004 | 05:16 PM
funina91ss's Avatar
to replace the seal you would have to remove the balancer, WP, opti, drop the oil pan, remove the front cover. not a small job by no means. but not really a hard one. It would make it easyer to remove the Radiator for more clearance.
Or you could clean it real good and put some RTV around where it is leaking from on pray it stops it.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
HectorM52
Jul 30, 2017 11:46 AM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
1LEThumper
Jul 14, 2003 12:45 PM
