Torque for alum. heads?
Old Apr 15, 2007 | 07:21 PM
hogs's Avatar
Hey Guys ,
Just wondering what you torque your heads to I heard the alum. heads require a little less Torque I was planning to go 50, 60 , 70, then 77 or 80 for the final pass..
I know some will think 65 but I have heard many times thats not enough...
So what is your thoughts on this..I am using Llyods LE2 heads and Le1.2 cam So am I good to go all the above numbers or?? BTW stock OEm gaskets and I think they are .029 thick
Thanks...?
Chris
Old Apr 15, 2007 | 08:53 PM
cnorton's Avatar
Obviously, you can squeeze them down as hard as you see fit but, personally, I would not go past 70#. Be advised that there is a point at which the threads will pull out of the block. I once had an earlier sbc Chevy block that pulled threads at 65#. That was several years ago but I've never forgotten the sickening feeling in the pit of the stomach when the tension on the torque wrench suddenly went slack as the threads came up. Nowadays, I typically stop at 65 pounds on my Super Stock LT1 when using a stock gasket. I've never had a problem and it regularly sees 8000+ RPM.
Good luck.
Old Apr 15, 2007 | 08:59 PM
VK's Avatar
VK
As long as you clean the block threads before you get started you shouldn't have problems. Everyone and their mother has their own specs that they like to torque everything to. If your just looking at what the crowd does to get an idea, your like me. I do 75 ft/lbs and have never had a problem. I don't see why 65 wouldn't work either.
Old Apr 16, 2007 | 01:20 PM
hogs's Avatar
Ok.. Since I am using Thread sealer on the head bolts does that increase or Decrease the amount of Torque?
Chris
Old Apr 16, 2007 | 01:25 PM
rskrause's Avatar
Moderator
Torque values will not depend on the head material but on the fasteners and the material used to lubricate them. ARP's site has some good info on fasteners.
Rich
Old Apr 16, 2007 | 02:06 PM
Stock torque is 65 for the heads.
Old Apr 16, 2007 | 03:07 PM
VK's Avatar
VK
All bow before the shoebox...
Old Apr 16, 2007 | 03:29 PM
Whatever that means...
I was just confirming the stock value, since no one else in the thread had. I don't know why it would not be sufficient. There are literally millions of engines using that value.
Old Apr 16, 2007 | 05:43 PM
96capricemgr's Avatar
Rich
That is what I told him a couple months ago when he asked on the b-body forum.
Old Apr 16, 2007 | 05:47 PM
VK's Avatar
VK
Just saying how your very helpfull. Its amazing how much information you have written about the LT1s! I have your page bookmarked and visit often.
I was just trying to say thank you in a big way i guess
Old Apr 17, 2007 | 06:24 PM
hogs's Avatar
I just torque my arp head bolts down to 40,50,60,70 75 and did one more final pass at 75 and all is good...
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
