top end cam!!
Old Jun 20, 2005 | 05:06 PM
LUDA0840's Avatar
Question top end cam!!
What cam would you guys recommend for my top end? I already have a good low end, just want to balance things out a bit. Thinking of getting a kit, so what cam would you guys recommend thanks!!!!
Old Jun 20, 2005 | 05:19 PM
jchevy's Avatar
Re: top end cam!!
You cam detemines the power band, so if you change the cam, you will change all the characteristics of the motor. So if you do a big cam, you wont have the bottom end power anymore.
Old Jun 20, 2005 | 05:23 PM
LUDA0840's Avatar
Re: top end cam!!
then what would you guys recommend?
Old Jun 20, 2005 | 05:27 PM
jchevy's Avatar
Re: top end cam!!
If you are looking for all around power do an LE1.
You sig says you are doing an LE Package soon, talk to him, tell him what you want the car to do and he can set you up with exactly what you want.
Old Jun 20, 2005 | 05:32 PM
LUDA0840's Avatar
Re: top end cam!!
yea i want to do a le1 or le2 sometime soon. Ill talk to him and see what he tells me.
Old Jun 20, 2005 | 08:53 PM
SStrokerAce's Avatar
Re: top end cam!!
LE2 cam is going to peak at about 6500-6600rpm so on a stock bottom end that's about all the top end you need.
Bret
Old Jun 20, 2005 | 08:57 PM
1racerdude's Avatar
Re: top end cam!!
Bret
And right after that he'll be hollering about his bottom end---- rods,crank,etc.
Old Jun 20, 2005 | 09:09 PM
Re: top end cam!!
Yeah, that part can happen.... most times it's because of the NAZZZ that helps the rod go stage right.
Hell I can't go much smaller with the thing and it has a stout enough TQ curve as it is....
Bret
Old Jun 20, 2005 | 09:14 PM
1racerdude's Avatar
Re: top end cam!!
Bret
Gtpguy
Jan 26, 2015 04:50 PM
Collector Car
Jan 5, 2015 10:58 AM
Jazsun
Dec 29, 2014 12:14 PM
