Took the car to the shop for mis.
Old May 3, 2007 | 08:20 PM
henryz28's Avatar
My car has had a mis fire for a long time now.Even before I did the cam swap.But the shop I took it to seems to think I did somthing wrong.They say the crankshaft sensor can throw every thing off and I cant run the dubble chain;I asked him if it could be tuned out and he toled me I absolotly need the crankshaft sensor.They toled me they have to degree the cam and put a stock chain on it for $700.I know I did the cam install right; and If I dident degree the cam correctly shouldent it be running way worse?In the end I decided to take my keys and take off.
Old May 3, 2007 | 08:31 PM
henryz28's Avatar
The reason I took the car to the shop is because it runs real bad once its wormed up.It mis fires and has no power down low;but after 3000rps it is fine.
Old May 3, 2007 | 08:43 PM
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
Just my .02 but when I had a similar problem it was my ICM(Ignition control module). Only misfired when car was warm. Take it to autozone and they can test it for free. Oh and he is full of crap, of course you can run the double chain, alot of people do it.
Old May 3, 2007 | 08:55 PM
henryz28's Avatar
Ok Ill do that right now.
Old May 3, 2007 | 10:03 PM
henryz28's Avatar
the ICM was good ;so I bought some new plug wires I am puting them on tomarrow.
Old May 4, 2007 | 01:23 AM
WSUFlyer's Avatar
If you can get ahold of a scanner....checkout your 02 readings. My car has a shorted out 02 and my car starts acting up when it gets warm. Acts like a miss and sometimes pops out of the exhaust, but when it hits 3000rpms it runs what seems to be 100%. I think I found a split in my driverside 02....just haven't had time to fix it.
Old May 4, 2007 | 02:09 AM
2000GTP's Avatar
Lots of things can cause misfire issues, don't think running a double chain is one of them though.
Old May 4, 2007 | 08:06 PM
henryz28's Avatar
Changed the plug wires and checked out the plugs.Diden't help;I did change my manafolds out with headers and I diden't change the O2 sensors.So I am just going to have the sensors checked out.
Old May 4, 2007 | 09:02 PM
Dave89IROC's Avatar
just FYI, the crank sensor on the LT1 is for misfire detection only, nothing else, however, the wiring to it , if damaged, CAN effect it, but thats it
ModdedNerd
Jan 1, 2015 10:56 AM
mspennyhughes
Nov 28, 2014 03:22 PM
draven666
Nov 26, 2014 07:16 PM
draven666
Nov 26, 2014 07:10 PM
USAirman93
Nov 24, 2014 03:37 PM
