Too Much Pressure In Gas Tank!!!
Old Nov 16, 2005 | 07:07 PM
Deenasty's Avatar
I need some help with my car guys. Everytime I open the gas tank cap, whether it has a full tank, half tank, empty tank, a lot of air blows out of the gas tank. Once the air stops blowing out, I put the cap on, and 10 seconds after, open it again, and the same air blow comes out. Also I am getting a "fuel" smell really bad, but no fuel is leaking anywhere. Is this a problem with the evap canister, or valve? Thanks!
Old Nov 16, 2005 | 10:53 PM
Deenasty's Avatar
Re: Too Much Pressure In Gas Tank!!!
Anyone???
Old Nov 16, 2005 | 11:13 PM
1racerdude's Avatar
Are ya sure it's blowing out and not sucking in? I presume ya upgraded your fuel system a while back and it may not have enough vent area.
Old Nov 16, 2005 | 11:41 PM
Deenasty's Avatar
yes it is blowing out. My fuel system is stock, besides 42lb injectors and a fuel pressure regulator. Besides that everything else is stock...
Old Nov 16, 2005 | 11:52 PM
1racerdude's Avatar
To have pressure or vacuum in the tank means it don't have enough vent. There is a white plastic check setting in a bracket where the metal brake line comes to join the flex line going to the rear end.Left side right on the inside of the front of the L rear tire. Check it and see if it is working properly.
There might be a chance that the charcole canister under the left front fender is kapoot. Disconnect it and plug the lines, if the check is working.
Old Nov 16, 2005 | 11:53 PM
Daniel6718's Avatar
i think i heard its beacuse we have a posative pressure tank or seomthing...dont worry mine does the same thing
Old Nov 17, 2005 | 10:23 AM
blackcar628's Avatar
The charcoal canister is just behind the gas filler neck, in the drivers side quarter panel.
Old Nov 17, 2005 | 10:52 AM
NeverEverSatisfied's Avatar
LOL... You guys are getting too technical for what could be a simple problem. Is your gas cap vented or not vented? A typical thing to happen with a non-vented gas cap is more pressure will build up in the tank. If you have a vented gas cap and you still are having problems then move on to the other "ideas". My 1991 Geo Storm (Winter Beater... HELL YEAH ) didn't have a gas cap when I bought it for $100... go figure... and I put a non-vented and it did the same thing my Camaro does. I work at a parts store so for ****s and giggles I bought a pre-vent and boom, problem fixed.
Just my 1/64 of a cent...
Old Nov 17, 2005 | 10:58 AM
Deenasty's Avatar
i dont have a vented cap, but if you put one on, wont you get a SES light?
Old Nov 17, 2005 | 12:10 PM
SweetZRag's Avatar
I had the same symptoms and it was the pressure relief valve mentioned earlier. Initially I solved the problem by putting a vented locking cap but then I kept failing inspection because they check those things in Jersey.
It is a big problem if you have a white Z like I do because the paint gets stained when it blows out. The valve was cheap and easy to replace.
Old Nov 17, 2005 | 12:17 PM
Nope... at least I haven't. As far as pressure checking I pass the Indiana inspection... they put 30 PSI on those suckers and I still passed w/o problems. My check engine light don't come on either. It will come on if you leave your gas cap at a gas station though...
Old Nov 17, 2005 | 12:58 PM
Deenasty's Avatar
What is the name of that valve? Fuel Tank Vent?
Old Nov 17, 2005 | 02:03 PM
SweetZRag's Avatar
Check this picture on Shoebox's site...
http://shbox.com/1/fuel_pump_wiring.jpg
He calls it Fuel tank vent.
ad356
Apr 16, 2015 05:38 PM
Magenta_Hearts
Mar 22, 2015 03:36 PM
Magenta_Hearts
Mar 5, 2015 07:01 AM
Deadbolt24
Jan 19, 2015 01:29 PM
blac94Z
Nov 24, 2014 07:12 PM
