too much fuel
Old Apr 14, 2003 | 11:25 PM
alexis01's Avatar
too much fuel
I just put a procharger blower w/intercooler on my 94 z28.. The car runs great, but it don't want to start.. I have to crank the hell out of it to get it to fire.. I'm pretty sure its gettin too much fuel, but I'm not positive. The car started perfect before supercharger install.. any suggestions on what it could be??? I thought about buying bigger injectors 30 or 36lbs. and tuning out my fmu.. will this help?
Also what size injectors would you recommend? Basically stock w/ exhaust and 8lbs. blower kit...
My fuel pressure gauge shows about 37 psi at idle and jumps to about 60psi at wot... if it helps..
Old Apr 14, 2003 | 11:44 PM
insomniac 92z28's Avatar
I would recommend strongly that you get dyno tuned ASAP. If you don't you will thrash your motor with improper tuning and a S/C.
Been there done that.
j/m .02
CaptainObviousI
29
Apr 29, 2021 10:35 PM
ad356
Apr 16, 2015 05:38 PM
charchri4
Apr 14, 2015 06:40 PM
2001CamaroGuy
Apr 5, 2006 10:56 PM
tbyrne
Jul 2, 2002 05:37 PM
