too much compression?
Old Feb 3, 2007 | 04:51 PM
gitsum's Avatar
How can you tell if your car is making too much compression? Will it bog down, stumble, miss, or something like that? When I did the cam swap, I had my heads milled and got b-body gaskets to raise the cpr. The machine shop ended up cutting about .0020 off the heads. Ive been trying to find out what my cpr would be, but cant find anything.
Old Feb 3, 2007 | 07:50 PM
ChevalierSS's Avatar
Were the heads milled 0.002" or 0.020"? The first, shouldn't have much of an impact on compression, the later will give a significant increase in compression. Neither one should be "too much".
Old Feb 3, 2007 | 07:53 PM
Another thought, what was the finished volume of the combustion chamber of the heads? The machine shop probably "CC'd" them for you. This number will be more important when calculating CR than the amount of metal milled.
Old Feb 3, 2007 | 08:10 PM
gitsum's Avatar
It was 0.020, and they didnt tell me the volume of the combustion chambers. Even with the head gaskets being 0.029 and the heads being cut that much, it would be alright to run pump gas?
Old Feb 4, 2007 | 02:41 AM
Z-RATED94's Avatar
Yes. Not a problem.
Quickss96
Jan 29, 2016 05:56 PM
surreybrad
Sep 29, 2015 09:00 PM
Daluchman1974
Sep 11, 2015 06:12 AM
13qtr
Jul 19, 2015 05:30 PM
pimpss96
Feb 12, 2015 01:28 PM
