Too late to change crank bearings?
Old Sep 22, 2004 | 07:13 PM
Kurt Crosbie's Avatar
I was wondering if there was actually a point at which just replacing your crank bearings would not fix anything (if the crankshaft was actually damaged).
I've got knocking coming from my motor. Local mech. says I'm about to spin a bearing. Does this mean that I can replace just bearings right now? Are the bearings what is causing the knocking?
Old Sep 22, 2004 | 07:37 PM
Re: Too late to change crank bearings?
You can't really tell what you are going to need without tearing it down first.
DirtyDaveW
Mar 15, 2015 07:01 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
1996LT1Z28
Dec 1, 2014 01:01 AM
Ken95Z28
Aug 21, 2002 04:32 PM
