Tire Width
Old Oct 29, 2004 | 10:32 AM
JAG05's Avatar
Tire Width
I have the stock 94 camaro rims, I have 245/50 R 16 on it. ANd i was wondering what is the widerst tire a can fit on it? Like can i put 275s or anything bigger on it??
Old Oct 29, 2004 | 11:04 AM
Red96Lt1's Avatar
Re: Tire Width
Some people run 275's on the stock rim, but I wouldn't reccomend it. 255's is probably the widest I would go.
Old Oct 29, 2004 | 11:15 AM
fesgali's Avatar
Re: Tire Width
There was some guy that ran 315s on a stock rim 97 WS6, but i wouldn't recommend it. The 245s are decent enough. If you really wanna get something out of your tires get some drag radials.
Old Oct 29, 2004 | 01:31 PM
Poik's Avatar
Re: Tire Width
Yours rims are 16x8. 255 is the widest you will want to go. 275s on the stock rim? Wow.
Old Oct 29, 2004 | 01:33 PM
TQdrivenws6's Avatar
Re: Tire Width
275s fit on the stock 9" wide WS.6 rims, thats how they came from the factory.
Old Oct 29, 2004 | 01:37 PM
mrr23's Avatar
Re: Tire Width
but he stated he has 16" wheels. the WS6 wheels are 17" i did a firebird once. using the stock 16 x 8 wheels, i put 265-50-16 all the way around without rubbing. but, when the TREAD width starts to exceed the RIM width, it will curl the edges and make the car squirmy. right now i have 335/35-17 on my 17 x 9.5 wheels. i change lanes and the car will wiggle side to side after making the change. but great straight line traction. cornering can be a little hairy though.
Old Oct 29, 2004 | 05:00 PM
snorkelface's Avatar
Re: Tire Width
335s on a 9.5" rim?!
Old Oct 29, 2004 | 05:30 PM
jonota's Avatar
Re: Tire Width
Wow... that's quite a stretch. IIRC, putting a wider than recommended tire on a rim not meant for it causes undue stress on the sidewalls. This can lead to such things as blowouts, especially at high speeds. It also in some cases can REDUCE the amount of contact patch you have.....
Jonota
Old Oct 29, 2004 | 06:04 PM
mrr23's Avatar
Re: Tire Width
it wasn't weasy getting them on. two tire irons to get them on. yes i know. i've been in the tire industry since 1993. but they were free. used fronts of a viper from macedo motorsports. they needed to throw them away. so i said i'll get rid of them for you. it saves on my new sumitomos when drag racing.
Novo
Wheels and Tires
14
Oct 12, 2015 11:20 AM
scottcba1
Sep 8, 2015 09:52 AM
Beave2780
Wheels and Tires
Sep 5, 2015 06:30 PM
Latronaxe
Jul 20, 2015 12:00 PM
Slayer
Jul 4, 2015 03:06 PM
