Tire Size?
Old Dec 18, 2003 | 06:18 PM
rgproc's Avatar
Tire Size?
I was just woundering if 255/50/16's will fit on my factory 16x8 wheels? Can I run these all the way around?
Old Dec 18, 2003 | 06:27 PM
2cub49's Avatar
They'll work fine in the back but will rub on hard cornering in the front.
Old Dec 18, 2003 | 06:54 PM
rgproc's Avatar
Should I go with 245/50/16 in the front? How will they fit.
Old Dec 18, 2003 | 06:55 PM
2cub49's Avatar
Those are fine for the front. thats the stock size.
Old Dec 19, 2003 | 02:02 PM
Just curious..... if the stock tire on a WS6 or SS coupe is 275/40-17, and it doesn't rub in the front, why would a narrower tire like a 255/50-16 rub in the front? I know the 255/50-16 is 0.40" larger in diameter than the 245/50-16 or 275/40-17, but that shouldn't be enough to cause things to rub. And I've used 17x9.5" wheels with both more offset and less offset than the stock wheels, and the 275's never rubbed.
Just curious.
By the way, if you have an edit program, or an HPP, you should revise the tire diameter in your PCM to 26.0" to avoid a speedometer error with the 255/50's. Only about 1mph error at 60 mph.
Old Dec 20, 2003 | 01:55 AM
my94blackz's Avatar
ive saw a 265/50 b4 i looked three times in disbelief. im running 285/40/17's up front on mine.
Old Dec 20, 2003 | 08:13 AM
Laymaster's Avatar
255's should fit with no problem.
HectorM52
Jul 30, 2017 11:46 AM
Fastbird93
Apr 9, 2016 07:01 PM
LD Kirk
Apr 30, 2015 08:54 AM
blac94Z
Mar 6, 2015 07:55 AM
cristian1311
Mar 4, 2015 04:45 PM
