tire and rim size limits
Old Aug 19, 2003 | 11:25 PM
newkoba's Avatar
Question tire and rim size limits
i was thinking about running the ROH black ice RT rims on my firebird formula, they make a 17x9 that i plan on running up fron with 275 bf goodrich g-force kdw tires. they also make a 18x10 that i want to run 315 or 345 on the back, does anyone know if they will fit on the rims or under the cars wheel wells?
thanks for the help in advance.
david
Old Aug 19, 2003 | 11:47 PM
Geezer powered's Avatar
18 by 10 should be fine for a 315 tire.18 by 11 will be better.
Old Aug 20, 2003 | 12:07 AM
newkoba's Avatar
will the 18x10 with 315 fit under the rear wheel wells? and what about up front with 17x9 275.
thanks again
david
Old Aug 20, 2003 | 12:12 AM
droptop1's Avatar
17X9 with 275/40's will fit fine up front. i dont know about the 18's with 315's in the back though.
Old Aug 20, 2003 | 06:51 AM
newkoba's Avatar
thanks for the help
Old Aug 20, 2003 | 09:29 AM
CeeBee94Z's Avatar
As long as you get a tire with the same height I don't see why it wouldn't fit. So just make sure that the overall height is the same as a 275-40-17...it will probably be around a 315-30-18 or so, but as long as it is the same it should fit without a problem
Old Aug 20, 2003 | 09:58 AM
IXLR894Z28's Avatar
You may have to roll the edges of the wheel well to prevent rubbing the tire over bumps.
HectorM52
Jul 30, 2017 11:46 AM
mschmidt33
Mar 15, 2015 07:20 PM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
Kato
Jan 26, 2015 09:21 PM
Azimiut
Jul 22, 2002 05:47 PM
