is the air pump needed to keep the cats alive, some say yes, others no?
Old Apr 8, 2003 | 02:53 PM
D James's Avatar
Ok Iv'e read over and over again about this, and it seems no one knows. I am planning on runing cats for my true duals longtubes and need to know if I should hook up the air aagain to keep them running and having a long life. I understand what the air does and all, but have heard without the air, the cats can't burn the exhaust off properly and start to clog it up, when the cats are cold. Thus the air heats them and keeps everything working properly. Now I've also heard some say they failed emissions without becasue it ruined the cats. I've also read that there was a recall on the Impala where a shop could legally remove the pump without worry of ruining the cat. So which is it? I understand that startup will put out more emissions without the pump, but I'm not concerned with that, since I don't have testing, I just want to clean up the air and stay semi legal and I hate to spend all that money on cats if they're going to be ruined because I failed to install the pump!
Old Apr 8, 2003 | 03:18 PM
norcalstreet's Avatar
The air pump is used to heat the CAT faster during startup. It's for emissions. I've never heard of anyone burning up a cat because the air pump was removed though.
Old Apr 8, 2003 | 03:23 PM
94_formula's Avatar
are you going to be running high flow cats, or just rig up 2 stock cats?? i dont know if it makes a diffrence, im just curious of your setup
Old Apr 8, 2003 | 06:09 PM
D James's Avatar
Hi flow cats, from what I've seen the car sound looks good, a comparison puts it at one of the best flowing and its fairly small http://www.lt1f-body.racenet.net/mufflers.php I can't seem to find any other cats that are thinner than 4inchs, the summit catco is cheaper, but I don't know how well it flows, and I 've read of people getting these car sound for around 70 bucks catco is 66. I've always loved the smell of cats, and they get rid of emissions, plus they kind of act as a muffler, so I'm going to try it. I wanted to use my X pipe, but I doubt it'll fit, and two single pipes will fit up better anyway. I get slack from people all the time who say oh thats horrible, you are hurting the environment, see fast cars are bad! I want people to know you can have both. I saw an article where some guy pulled over 650 horses with a supercharger, and passed with flying colors on the smog. So really there s no reason not to have them, unless you cant afford them, or don't have the room like our cars I'll probably go with something lie this, it looks real good! http://pages.sprint.ca/modpics/files/3dualalb.htm
HectorM52
Jul 30, 2017 11:46 AM
95chwagon
Jan 13, 2015 09:19 PM
cmdeshon
Dec 27, 2014 10:06 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
