Tips on installing a Hooker exhaust???
Old Jun 7, 2003 | 11:28 AM
Raider Z28's Avatar
I plan on instlling my new Hooker exhaust on my 96 Z28 and wanted to know if are any tips are tricks to the install.
Old Jun 7, 2003 | 11:33 AM
jkipp84's Avatar
Make the cut on the stock I-pipe just in front of the rear axle. When installing the new cat-back, get all the pieces in place without tightening them too much. There's going to be a bit of back and forth here and there, adjusting where things sit before you have it just where you want it. Tighten down as you go.
Crank it up, check for any leaks, crack a cold one, and start thinking about that header install...
Old Jun 7, 2003 | 11:38 AM
Raider Z28's Avatar
Jkipp,
When you say make the cut??? I thought it would be a direct on with o fabrication. Why is the cut necessaary?
Thanks for your help.
Old Jun 7, 2003 | 11:44 AM
jkipp84's Avatar
The stock pipe needs to be cut to remove it (or drop the rear, I suppose). If someone has some sort of trick for removing it without cutting it, I've never heard of it.
It's really not that bad, a hack saw, air tool cutter, pipe cutter, machine gun, what ever works.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
alex5366
Feb 17, 2015 09:07 AM
Jan 5, 2015 07:14 PM
ModdedNerd
Jan 1, 2015 10:56 AM
