Tip for getting the final motor mount bolt back in?
Old May 23, 2013 | 01:27 AM
94Form's Avatar
Had to raise the motor for the LTs, went back down and got 5 bolts back in no problem. The sixth bolt won't go in because there is another bolt right in its way. Name:  ScreenShot2013-05-23at10723AM_zpse5076a82.png
That is the bolt I can't get in and obviously the bolt right next to it is in the way of it going in. It seems like that bolt is holding on the mounting bracket so I didn't want to touch that. Maybe im wrong?
I tried raising the motor again and slowly lowering it onto the bolt but the block would always push it out before the holes would line up.
Is there any tips on getting this bolt back in there?
Old May 23, 2013 | 02:20 AM
Chet1185's Avatar
I put that bolt in through the back and held the nut and threaded the bolt into it.
Posted from Camaroz28.com App for Android
Old May 23, 2013 | 05:59 AM
Greg88's Avatar
Re: Tip for getting the final motor mount bolt back in?
Exactly what I just did. Held the bolt tight to the motor mounts between the mount and that already existing bolt head and fed the motor mount bolt from the back side! Easy as pie!!
Old May 23, 2013 | 07:52 AM
94Form's Avatar
Thanks for the replies, I'll give it another go
Old May 23, 2013 | 10:57 AM
LT4Monsta's Avatar
When I did it I installed that bolt you have circled first in first, then I put in the bolt to connect the engine mount to the bushing. Then I lifted my motor up a bit to get better clearance and tightened down the bushing bolt itself. It's so weird how easy the LT1 is to work on things that seem impossible to reach when you just shift the motor around a little.
Old May 23, 2013 | 02:53 PM
Yeah, I think I tilted mine a bit to change the angle of the bolt in the mount to the block.
Old May 23, 2013 | 08:50 PM
white97T/A's Avatar
Sounds like you are going about this the hard way. All you need to do is take the horizontal bolt out to lift the motor up a bit. No need to unbolt the clamshell from the block. When I installed my headers I only had to lift the passenger side of the engine to install the passenger side header. Drivers side goes right in fom the bottom with no issue.... I just did the yesterday so I know it works.
Old May 24, 2013 | 01:18 PM
97WS6SCharged's Avatar
Yep. Yanking the through bolt is much easier. Plus the rubber inserts could probably stand to be changed if you're just getting around to doing headers.
Old May 24, 2013 | 11:24 PM
new2chevy's Avatar
Since those two bolt heads are touching or darn close to touching, and you cannot get a socket on the horizontal bolt, this means your motor mount is bad.
Replace that sucker.
Old May 25, 2013 | 12:13 AM
94Form's Avatar
Bolt is back in. Just supported the engine and took out the horizontal bolt. Thanks for the replies guys
Old May 25, 2013 | 12:22 AM
new2chevy's Avatar
It looks like You should change out that motor mount bushing. The two bolt heads should not be so close together. When I changed my motor mount inserts, there was room to put a socket on the horizontal bolt, with the engine totally resting in it's natural position.
HectorM52
Jul 30, 2017 11:46 AM
thenewkid
Nov 18, 2014 12:57 PM
1LEThumper
Jul 14, 2003 12:45 PM
