Tip - Gasket Removal
Old Apr 7, 2003 | 03:54 PM
TobyZ28's Avatar
Use spray on gasket remover to help remove stuck on gaskets! It works great!
I'm definatly not a mechanic and have been working on small
stuff on my car for the last year or so, but I didnt know this stuff existed and wish i did sooner So Hopefully this helps someone out (Just changed my differential gasket it was leaking). Before I was going nuts with the scraper trying to get it all off.. never again! It just wiped right off after applying the gasket remover...
Old Apr 7, 2003 | 03:58 PM
chasmanz28's Avatar
Re: Tip - Gasket Removal
yes i bought the spray also and herd good things about it going to do the intake gasket this weekend
Old Apr 7, 2003 | 04:01 PM
TobyZ28's Avatar
With the differential gasket i did i had some REALLY nasty gasket pieces stuck on, previously we used some gasket sealant to make a better seal... Just follow the instructions and wait the 5-10 minutes of soak in it recomends.. and repeat if it doesnt just comme off when u take the putty knife to it. I was able to get the surface shiny smooth after repeating the spray 2-3 times on the harder spots... it'll eventually get it all of just be patient and wait for it to soak in
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
Jun 6, 2015 08:27 AM
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
Queens94z28
Dec 20, 2014 09:11 PM
