Timing/Retard issues, please help!
Old Jun 8, 2006 | 09:17 PM
hozb817's Avatar
Just installed new opti and timimng is off pretty bad, we checked everything possible, knock modules, knock sensor, plug wires, coils, MAF, and the list goes on. Does anyone know of something else that would make the timing off? any advice and help is appreciated!
Old Jun 8, 2006 | 09:28 PM
1racerdude's Avatar
Re: Timing/Retard issues, please help!
Is yours NON vented? If so did you line the master spline up right?
If it has been converted to vented the only thing it could be is the drive pin is not in the correct slot.
Old Jun 8, 2006 | 09:37 PM
DLindlZ28's Avatar
man im haveing the same problem if u find out let me know plz
Old Jun 8, 2006 | 10:06 PM
Plug wires in the wrong place may make it act like the timing is off or else you just got the opti indexed wrong.
Old Jun 9, 2006 | 08:04 AM
hozb817's Avatar
its definatly non vented, and all the plug wires are in the correct places, what else could be the issue?
Old Jun 9, 2006 | 08:35 AM
He already asked.... are you POSITIVE you aligned the splines in the driveshaft correctly?
It turns out it is VERY easy to assemble the splines incorrectly, even though there is the "odd" spline that's only supposed to slide in one way. I bet 10-20% of the people manage to assemble it incorrectly.
Old Jun 9, 2006 | 09:40 AM
hozb817's Avatar
everything was taken off, and re assembled correctly
Old Jun 9, 2006 | 09:44 AM
jsetzer's Avatar
Then it should run correctly.
/thread
Seriously though, how do you know "the timing is off pretty bad"?
Old Jun 9, 2006 | 09:53 AM
Heard that before..... and several posts later the Opti was found to be indexed incorrectly. But if you're SURE..........
Old Jun 9, 2006 | 01:12 PM
hozb817's Avatar
myself along with another LT1 inclined friend, uninstalled everything and reinstalled to the T, the timing is of due to us checking with a timing light, so any other suggestions, maybe a sensor I have over looked?
Old Jun 9, 2006 | 02:38 PM
Perhaps you had some experience looking at it with a timing light when it was running correctly and used that for reference (since timing lights are not really used for diagnostics on these cars). If it does actually look off, then the computer has mysteriously changed something or the opti is indeed indexed wrong (as preposterous as that may seem).
Old Jun 9, 2006 | 03:59 PM
Timing depends solely on the input from the Opti optical sensor, and the timing tables in the PCM.
Apparently in the past you put a mark on the damper, correlating that to the timing advance shown on a PCM scanner.... is that correct? And now you are comparing the advance as indicated on the mark on the damper, and when comparing it to the advance shown on the scanner, they do not agree?
Or did you figure some other way to utilize the timing light?
Old Jun 9, 2006 | 04:05 PM
jsetzer's Avatar
Ya, how exactly are you using it?
Get a reading from the pcm, thats what matters.
You are still being extremely vauge. Off? How is it off? Is it too high? Too low? Does it jump around?
We can't help you if you just say my timing is off.
Old Jun 9, 2006 | 06:07 PM
hozb817's Avatar
ok, it idles fine, but when the throttle opens up the timing does the opposite of advances, looks like at least 15 degress, we marked the crank pulley/damper TDC and when accelerated mark moves to the right, minimum of 15 degrees, please help! we have removed and reinstalled the brand new opti about 4 times now, every time same result
Old Jun 9, 2006 | 11:37 PM
Have you scanned it for knock retard?
