Timing loss top end, can a busted/loose cat converter do this?
Old Jun 26, 2010 | 08:21 PM
RACEON's Avatar
The timing and performance on a friends Vette is slipping at top end/WOT runs. He noticed one of his catalytic converters was making a rattling noise on his 96 LT1.
Can a cat cause this kind of problem making the ECM think there is spark knock?
ALso, someone told him its normal for SLP metal matrix cats(similiar to his) to rattle as they expand and contract so they will be loose in there casing.
Old Jun 26, 2010 | 09:30 PM
ACE1252's Avatar
In my experience, if a cat rattles, it's not a good thing.
Old Jun 27, 2010 | 08:41 AM
Wild Willy's Avatar
If the cat gets partially clogged, it can cause excess backpressure at higher rpm's and loads, and even cause real knocking-
Old Jun 27, 2010 | 09:23 AM
How did you determine "timing..... is slipping"? Do you mean you put a scanner on it and it is getting knock retard?
Old Jun 27, 2010 | 10:53 AM
RACEON's Avatar
Yes, it is pulling 4-5 degrees at above 5000 rpm from what is programmed in for timing.
The sensors are put in with teflon tape and torqued to 14ft/lbs? and there is an LT4 knock module in there.
Old Jun 27, 2010 | 10:57 AM
Is it possible you have a fuel pump problem? Have you checked the pressure?
Old Jun 27, 2010 | 10:58 AM
RACEON's Avatar
He has a Racetronix fuel pump in the Vette. That should be fine and he is running a 43.5 psi with vacuum off. TR55 plugs and a new opti, GM Opti.
Old Jun 27, 2010 | 02:48 PM
What is the pressure at WOT when the engine starts to drop power and knock?
Apparently Walbros never go bad????
Old Jun 27, 2010 | 03:09 PM
RACEON's Avatar
43.5 on the dyno when intially tuned.
Old Jun 27, 2010 | 09:32 PM
But its not on the dyno, and you are indicating the engine is losing power at WOT. Have you rechecked the fuel pressure?
Old Jun 28, 2010 | 12:44 AM
RACEON's Avatar
I will have him check it. thanks
Gtpguy
Jan 26, 2015 04:50 PM
Collector Car
Jan 5, 2015 10:58 AM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
