Timing loss top end, can a busted/loose cat converter do this?
The timing and performance on a friends Vette is slipping at top end/WOT runs. He noticed one of his catalytic converters was making a rattling noise on his 96 LT1.
Can a cat cause this kind of problem making the ECM think there is spark knock?
ALso, someone told him its normal for SLP metal matrix cats(similiar to his) to rattle as they expand and contract so they will be loose in there casing.
The sensors are put in with teflon tape and torqued to 14ft/lbs? and there is an LT4 knock module in there.
Gtpguy
01-26-2015 04:50 PM
