?? Timing gears
Old Jun 3, 2003 | 03:50 PM
toolmaker's Avatar
?? Timing gears
Can any one tell me if I can use a double roller on my 93 lt1? Will the gears from a lt4 work or does any buddy make a set for the 92-93's. Any info would be great. THANKS
Old Jun 3, 2003 | 03:56 PM
thewinner's Avatar
you will need the double roller sprockets since its basically 2 chains together. and also an electric water pump
Old Jun 3, 2003 | 04:00 PM
Buttercup's Avatar
Don't forget the vented opti! If you have your heart set on upgrading the timing set, it's good peace of mind for running an aggressive valvetrain. Truth be told, the stock timing set is usually enough for just about any cam/valvesprings you're going to run on the street though.
ChrisFrez
Dec 15, 2014 03:09 PM
Noenav
Dec 6, 2014 07:35 PM
1LEThumper
Jul 14, 2003 12:45 PM
