Learn me on timing sets!
Old Jan 1, 2004 | 04:49 PM
ibanez6rg's Avatar
Talking Learn me on timing sets!
From what I understand: I will be either upgrading my stock set with an LT4 HD or Cloyes timing set. And in order to upgrade to a 95+ I will also need to purchase; 95+ opti, timing cover, vac harness, and vac fitting. I know all that is needed for the LT4 HD, but all this is also needed for the Cloyes chain?
I also here the Cloyes is a lot cheaper. Can anyone point me into the direction of one. P/N?
Thank ya!
Old Jan 1, 2004 | 05:13 PM
smokerZ28's Avatar
www.cmotorsports.com
CL-3145 $79.97 Cloyes True Double Roller Adjustable Timing Chain Set
Bout $200 cheaper than the LT4 set at cm. You also have to use an elec. water pump with the double roller. So if you don't wanna dish out the $200 for a Meziere, I guess the LT4 set is the option.
Old Jan 1, 2004 | 05:26 PM
ibanez6rg's Avatar
I already have a CSI electric waterpump. Does the Cloyes come with the cam/crank sprockets?
Old Jan 1, 2004 | 05:38 PM
Brandon 95 Z28's Avatar
After speaking with combo, i decided to go with their double roller timing chain set. It is 10.00 cheaper then the cloyes, and supposedly has stronger crank gear teeth, not that the cloyes are weak. They both should come with the cam and crank gear as well.
Brandon
HectorM52
Jul 30, 2017 11:46 AM
barry76lt
Events and Cruise Spots
13
Jul 21, 2015 06:17 AM
Jlo
Feb 3, 2015 09:41 PM
Queens94z28
Dec 20, 2014 09:11 PM
