Timing Chain / Set Options?
I have searched and found some old threads, but didnt find any answers really.
I have just about everything purchased for my Z28 build with the exception of the timing chain.
The cam is a LE grind on a billet core. It is a 236/236 @ .050", I will be using 1.6 NSA rockers with 7/16th studs and the valve springs are Comp Bee Hive Springs (unsure of the weight).
I will be using the stock water pump so I need it to work with that.
So basicly the only choices I have are:
Stock = $110 From GMpartsDirect With Sprockets
Maybe a OEM equivelant made by someone else?
LT4 Chain = $250 from jegs
when looking for the cam gear I get an option for 93-97, or 95-97. one is more expensive. I dont understand, I have a 95 how do I know what one I need?
What else is out there?
What do you recomend?. I dont want to spend more than $130 if I dont have to.
http://shbox.com/1/4th_gen_tech2.html#Dal_and_Jason
Try this link. Infact, bookmark his site. Sometimes it is easier to use his site than my factory manual. Lots of useful info. He put a lot of time into it , guessing from the many pages, photos, etc.
I found this on ebay
http://cgi.ebay.com/ebaymotors/Lunat...spagenameZWD1V
but Is that just a OE replacement?
Or, maybe it would be a good idea to just go with the electric water pump, then I would be able to get a nice strong chain for a good price.
what are my options then?
http://cgi.ebay.com/ebaymotors/CSR-B...spagenameZWDVW
there is the waterpump. can I use just about any chain then?
what about modifying the cover?
I am not a believer in the whole idea that we have to use electric pumps so we can use "good" chains.
Stock setup was made with the substantial load of the WP in mind, if you think it is weak just swapping to an electric WP alone would take substantial load off of the chain thereby making it less likely to break.
Maybe we will run into eachother at WIR or GLD.
