Timing chain question...
Old Nov 21, 2009 | 10:00 PM
charliediss's Avatar
I am installing the front of the 396 and after I installed the heavy duty timing set I check out the slack and it seems like the chain is too loose. How far should the chain deflect, or should it deflect at all? I got this set second hand so I do not want to install a stretched timing chain...even though it supposedly had under a thousand easy miles on it.
Thanks!
Old Nov 22, 2009 | 01:33 AM
monster81's Avatar
not sure about the HD Timing Set, but when i installed a new stock timing set, it had a bit of a slack. i guess i was able to move the chain like about a 1/4" back and forth on each side, i was worried but then when i run the engine everything was fine
Old Nov 22, 2009 | 10:10 AM
Is it possible the "sunk" the crank when they align-bored the mains?
Old Nov 22, 2009 | 01:41 PM
Kevin Blown 95 TA's Avatar
Still, a little slack in the chain doesnt translate into very much unwanted rotational movement of the cam vs crank.
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
