Timing chain question
Old May 23, 2006 | 01:45 AM
arcticz28the383's Avatar
http://store.summitracing.com/partde...0&autoview=sku
I want to get this timing chain for my 383 I'm building because of my non vented opti. I have a lunati one here, but I'm too nervous to put the thing on because of the amount of money I've spent on this project.
I have one question though, where is says 'verify as to a smooth or splined hole in cam sprocket', what exactly does that mean? Are they refering to the splined hole the opti drive goes into? If so, thats what I want, correct?
Old May 23, 2006 | 05:07 PM
seawolf06's Avatar
Re: Timing chain question
Ideally you should just get the vented opti and then you can get a cloyes double roller for cheap, unless you already have the new cam or don't wanna change the cam sprocket. I'll be selling my opti soon if you're interested.
Old May 23, 2006 | 05:39 PM
Dave89IROC's Avatar
agreed, a new build is the perfect time for a vented swap, get the correct cam, timing set, front cover, and the elect. harness and vac harness, then all you need is the opti
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
GigaMp3z
Feb 20, 2003 02:57 PM
