Timing chain for High rpm Solid roller
Old Mar 10, 2009 | 08:47 AM
whyrun's Avatar
I did a search on this but didn't really uncover any good answers, I'm build a high rpm engine with a high seat pressure solid roller. And I'm wondering who makes a good double roller setup that will work on a gen2. I will be running a Elec WP and More than likely the stock cover unless there's a aftermarket unit that will work better this is a drag car setup..
Old Mar 10, 2009 | 09:05 AM
Nostang 96z's Avatar
http://store.summitracing.com/partde...A&autoview=sku
This is the chain I have in my high rpm solid roller I am building.
Old Mar 10, 2009 | 09:20 AM
DelSoto's Avatar
another vote for the Cloyes DR. I used the stock wp housing and a CSR water pump.....very happy with it.
Old Mar 10, 2009 | 09:28 AM
cnorton's Avatar
I've been there and done that. There is only one really effective option for the application you have described (high lift, solid roller, high RPM, drag race-only). Any choice other than a Jesel belt-drive is a compromise. I have run this set up on my NHRA Super Stock LT1 for six years with no problems. The Jesel catalog does not specify a belt-drive kit for the LT1 but it's an easy adaptation. It also allows you to run an SBC gen 1 damper and timing pointer, an option that I found to be a plus.
Old Mar 10, 2009 | 01:34 PM
whyrun's Avatar
I would not be aganist the idea of the Jesel Belt drive, how does it work with the opti ? could you post some pictures. I can't get a good picture of it in my head..
Old Mar 10, 2009 | 03:31 PM
cnorton's Avatar
Sorry, please disregard my suggestion. I don't think there is a way to do it while maintaining the optispark. I converted the ignition to a crank trigger and a belt drive distributor. The optispark seemed like a serious liability in conjunction with 8000+ RPM. I can make them live at 7300 without much problem but the extra RPM opened the door to even greater potential for failures.
Old Mar 10, 2009 | 08:26 PM
whyrun's Avatar
yeah I kinda thought it would be hard to do that with an opti. But I have been thinking about a crank trigger setup, I know the basic's behind the crank trigger how hard was it to install was their alot of fabrication or was it fairly straight foward
Old Mar 10, 2009 | 09:25 PM
cnorton's Avatar
The primary challenge to fitting an out-of-the-box small block crank trigger to an LT1 is to extend the pick-up bracket farther forward to reach the extended damper. I machined a completely new pick-up bracket that is a bolt-on fit for use on the Stock Eliminator cars that are required to run an Optispark. Of course, by putting a Jesel on my Super Stock motor, I was able to use a first generation small block damper and the crank trigger kit fit without complications.
Old Mar 10, 2009 | 10:55 PM
I've had no problems with the LT4 Extreme Duty set, with a solid roller and a 7,200rpm redline. The shop did drill 5 holes in the cam sprocket to reduce the excessive weight though. A buddy of mine running closer to 8,000rpm also used the LT4 ED with no problems.
Old Mar 11, 2009 | 01:22 PM
whyrun's Avatar
Thanks for the replies. I think I'm going to go with that coyles hex adjust timing chain, I'm really digging the features it has. I would really like the Jesel belt drive but I'm getting hyper about lighting this engine up so the Fancy'r I get with this thing the more money I have to save to get it finished so maybe save the belt drive and crank trigger setup for a later time.
Cam's maro
Jan 30, 2015 09:21 PM
95chwagon
Jan 13, 2015 09:19 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
