Problem with injectors..
Old Mar 11, 2009 | 12:37 AM
dubbsix's Avatar
or maybe I need different injector clips, but I am having trouble getting my bosch injectors to fit with the OEM injector clips because the ring around the replacement injector doesnt go all the way around like the stock one..
Is there a different injector clip.. or do i need to get a set of injectors that have the retainer grove all the way around the injector??
Old Mar 11, 2009 | 05:26 AM
Common problem with the Bosch/SVO/FMS injectors. A lot of us run without the clips. Once the rails are tightened down, there's no place for the injectors to go. The can't fall out. I have a set of Bosch 64's, running at 58psi, no clips, and haven't had a leak in the 9 years they've been in the engine.
Old Mar 11, 2009 | 10:27 AM
dubbsix's Avatar
Thank you for your reply Injuneer. I jokingly told my wife we would just run them without the clips and she almost spit out her beer lmao.
Old Mar 11, 2009 | 01:24 PM
WS6T3RROR's Avatar
I run my fast injectors without the clips @ 60psi. 45k miles 3 camshafts and 2 port jobs later no leaks. What I will say is to install the injectors deep into the fuel rail and try to have them sit high in the boss on the intake to keep them in place. I have seen some slip down just a bit on others cars but mine havent moved.
Old Mar 11, 2009 | 02:03 PM
C_Rules's Avatar
i run delphi 42s @ 48psi without them. no problems.
Old Mar 11, 2009 | 02:24 PM
Nissenexcavating's Avatar
Never used the clips nobody i know with aftermarket injectors does either. Dont worry bout it
Old Mar 11, 2009 | 03:00 PM
bombebomb's Avatar
No clips here, no one uses them on aftermarket injectors.
Old Mar 11, 2009 | 03:06 PM
dubbsix's Avatar
Yea i'll make sure to see that they are snug in the bosses and seated properly before putting the intake back on the car. Thanks guys.. i was fearful i'd have to buy a different set.
liamcg97
Nov 25, 2019 05:55 PM
daves91z28
3rd Gen / L98 Engine Tech
May 12, 2016 06:19 AM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
