Timing chain with gm847 cam
Old Feb 25, 2008 | 07:40 PM
a4z28's Avatar
I am going to be doing my cam swap next weekend and was wondering if i would need to change the whole set or just the chain. My cam is the gm847 with stock heads i will be spraying 125 shot also. Thanks
Old Feb 25, 2008 | 07:45 PM
ss.slp.ls1's Avatar
Whenever I read about timing chains, I have read to replace the whole timing set and NOT just the chain, as just replacing the chain will cause premature wear on the gears and/or chain.
Old Feb 25, 2008 | 08:09 PM
dangalla's Avatar
very true, i would just use a stock replacement set
Old Feb 25, 2008 | 08:42 PM
brain's Avatar
Ideally, with a 125 shot and that cam, I'd strongly recommend a double roller. However, you then need an electric water pump. With that being said, I did run the 847 on a stock replacement chain, and sprayed a 150 shot with no issues. Motor is still running great, but doesn't have the gas on it, and it's been a few years, spinning it to 6700, daily driver.
Old Feb 25, 2008 | 10:01 PM
dangalla's Avatar
why? when is the last time you heard of a stock one breaking.
Old Feb 26, 2008 | 10:51 AM
brain's Avatar
Most people here with heads/cam and making good power have already gone to a double roller chain, or at least the LT4 extreme duty. It's cheap insurance I guess. Why become the thread starter for the My motors shot cause the timing chain broke. A stock head 847 with a 125 shot should make over 500 ft. lbs of torque. Why take a chance if you have the cash to do it right?
Old Feb 26, 2008 | 11:44 AM
The timing set is driving the cam and the water pump. How much do those loads increase with HP/torque?
Old Feb 26, 2008 | 11:48 AM
dangalla's Avatar
ha ha. none. but go ahead and try to explain that to one of these internet cowboys. best to just let em waste there money if they want.
stock chain, stock sprokets here, if i ever have a problem i will be sure to let you know, but i would be sure that you will have a problem before i do.
Old Feb 26, 2008 | 12:15 PM
'94 Bad A Z28's Avatar
I have a stock replacement timing set in my 847 car.
Old Feb 26, 2008 | 12:37 PM
jsetzer's Avatar
I would think that increased seat pressure pushing down on the more aggresive cam lobes would affect it, but I'm just an internet cowboy.
My stock 110k mile chain had less slack in it than my 10k stock replacement one did on my cc306.
Old Feb 26, 2008 | 01:15 PM
Steve in Seattle's Avatar
Post
e-WP helps... but I went with a LT4-XD chain set just to be sure.
you can try a slightly larger sprocket to tighten up the chain as well... but opinions are mixed on that as well.
Old Feb 26, 2008 | 02:09 PM
Point is, the 500 lb-ft of torque is not what affects the load on the timing set, particularly when most of that comes from nitrous. High RPM solid roller, with huge seat pressures is an issue.... I run the LT4 ED, but basing the selction of the timing set on how much torque the engine makes is questionable, at best.
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
GigaMp3z
Feb 20, 2003 02:57 PM
