spark plug
Old May 20, 2007 | 12:30 PM
Geezer powered's Avatar
spark plug
anyone running +1 or +2 heat range in there lt1? if so what are you running?
Old May 20, 2007 | 08:26 PM
Do you mean 1 or 2 steps hotter? I doubt anyone would want to do that, if that's what you mean.
Old May 20, 2007 | 09:34 PM
yeah thats what I ment. I'm getting some oil on my #7 spark plug. I wanna put a step hotter plug in there just for the summer. Then in the fall /winter do a tear down of the motor and rebuild the heads. I think my valve guide has gone bad.
Old May 21, 2007 | 12:46 PM
2000GTP's Avatar
Usually people switch to a colder plug. Even so, I don't think it is going to help the problem that you are having.
Old May 21, 2007 | 05:16 PM
Hot plugs will resist fouling, to some extent. But then you increase the risk of detonation.
Old May 21, 2007 | 05:41 PM
Wink
I know the promblem will not go away until I fix that valve guide seal. The plug has'nt fouled yet. I'll pull it and clean it at every oil change ( 1,500 for me on regular dino) I just want to make sure that #7 is fireing at full strenght. I think I might just keep it or maybe just put a hotter plug in that one cylinder. Any suggestions on a hotter plug? I'm not to worried about detonation in that one cylinder with a hotter plug, The car runs on the rich side
Old Feb 26, 2008 | 06:32 PM
The_Bishop's Avatar
Guess what, Geezer... The problem didn't go away; I inherited it. Now I'm pulling the intake manifold.
jwade88
Jun 14, 2015 09:38 PM
jayblev95
Jun 7, 2015 04:04 PM
blkWidow
May 3, 2015 08:42 AM
nikko
Apr 20, 2015 07:56 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
