Timing chain cover hub seal
Old Mar 30, 2008 | 10:54 PM
lt1loudmouth07
Guest
Posts: n/a
Do i have to take off the cover to change the seal or can i leave everything in because the seal is leaking very bad at the bottom on the hub of the timing cover
Old Mar 30, 2008 | 10:57 PM
dangalla's Avatar
if its the same as a 97 then yes you need to remove the cover IIRC it comes out the back side of the cover
Old Mar 30, 2008 | 11:45 PM
SS RRR's Avatar
if you mean the crank/hub seal then no the timing cover does not have to come off. you just need to pull the hub. you can then carefully pry the seal out using a flat head screwdriver. make sure not to gouge the crank.
put the new seal in by tapping on it with a mallet until it's flush.
make absolutely sure there is no rust or debris where the hub rides on the seal or it'll eat through the seal in no time and you'll be right back to square one. i've used a "rust be gone" solvent on mine to ensure a clean hub before putting back onto the crank.
Old Mar 30, 2008 | 11:49 PM
The timing cover does not have to come of to change any of the round seals in it. All seals come out the front.
Old Mar 31, 2008 | 12:08 AM
lt1loudmouth07
Guest
Posts: n/a
seal
Thank god lol. Thank you guys
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
GigaMp3z
Feb 20, 2003 02:57 PM
