damper hub bolt = loctite
Old Mar 29, 2008 | 04:56 PM
dangalla's Avatar
so i had this knocking sound start not to long ago, and it has been getting worse. it sounded just like a bad belt tensioner so i just replaced that because i really did not have time to get into it last week and it was like the only thing not new under the hood.
when that did not fix the problem i dove further into it today and eventually found that the damper hub bolt had backed out allowing the hub to back out slightly and let the crank sprocket bounce around, causing the knocking noise. this motor only has like 3500 miles on it and i know i had that bolt tight before. lucky for me the bolt had not backed out completely and i caught it in time.
just figured i would put this out there to warn others, its a good idea to put loctite on there
Old Mar 29, 2008 | 10:29 PM
Dave1980's Avatar
stock crank?
Old Mar 29, 2008 | 10:30 PM
dangalla's Avatar
Originally Posted by Dave1980
stock crank?
yeah and the stock damper and hub also
Old Mar 29, 2008 | 11:06 PM
speed_demon24's Avatar
You probably didn't torque it enough. I've had mine off 10+ times and it never backed out on me.
Old Mar 30, 2008 | 01:52 PM
marshall93z's Avatar
Your crank sprocket moved? That thing is usually on there pretty tight!
Old Mar 31, 2008 | 12:08 AM
Dave1980's Avatar
Yeah mine was a bitch to get off.
HectorM52
Jul 30, 2017 11:46 AM
maybe2fast
Mar 16, 2015 09:45 AM
cyteone
Feb 7, 2015 06:04 PM
Chevyguy358
Jan 28, 2015 08:04 PM
