timing chain clearance problem
Old Jul 22, 2006 | 06:00 PM
ajschult's Avatar
We are in the process of re-assembly of my new 383 and ran into a problem. We are trying to get the timing chain put on right now and had no problem getting the dots to line up, but when I go to spin the crank something hits and we cant spin the crank any further. I spun the crank by itself without any timing chain on it and it goes around smoothly. Same with the cam, when there is no chain on it it spins freely. But as soon as we put the chain on and spin them both at once something hits. Anyone have any ideas as to what may be hitting? I cant visually see anything, but we can definately hear it hitting somewhere.
Old Jul 22, 2006 | 06:05 PM
Birdman7389's Avatar
Re: timing chain clearance problem
I know the Crank position sensor needs removed with a double roller, and there is a little grindng you have to do to the inside of the timig cover.
Old Jul 22, 2006 | 06:08 PM
ajschult's Avatar
Should have mentioned that this is a stock timing set.
Old Jul 22, 2006 | 06:13 PM
IllusionalTA's Avatar
is the valve train setup?
Old Jul 22, 2006 | 06:16 PM
ajschult's Avatar
no, no valvetrain
Old Jul 22, 2006 | 06:17 PM
ajschult's Avatar
it only runs into problems when the chain is on, when its off the cam and crank spin fine.
Old Jul 22, 2006 | 07:36 PM
1racerdude's Avatar
Put some grease on the cover and see where it is hitting.
Looking from the side are the sprockets lined up? Ya will need a straight edge to check it.
Is the reluctor wheel on correctly?
Old Jul 22, 2006 | 08:16 PM
sam pace's Avatar
Your cam could be to big for your setup.
You might need to get a small base circle cam.
Old Jul 24, 2006 | 08:30 AM
that's a good point!
Old Aug 3, 2006 | 09:24 AM
Victory Racing's Avatar
I'm inclinded to agree with same, I think you have a rod crashing into the cam. When you spin them alone they are getting by one another, but as they spin together the rod is catching the peak of the lobe.
As for clearancing covers. Its really a crap shoot. I use 96-7 covers on most of my stuff and only have to clearance maybe one in ten if that.
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
GigaMp3z
Feb 20, 2003 02:57 PM
