Timing Chain???
Old May 25, 2004 | 03:12 PM
camaro325's Avatar
Timing Chain???
what is the strongest timing chain and gears for the LT1.....also would the Lt4 gears and chain be good for an LT1, and how nuch horsepower would it handle, thanks.
Old May 25, 2004 | 03:39 PM
kmook's Avatar
Advanced Tech Moderator
This would be best discussed in LT1 Tech, transfering.
And yes the LT4 stuff is good, but even better is a true double roller setup (though you need a electric water pump then).
Old May 25, 2004 | 05:00 PM
The LT4 Extreme Duty timing set has been used on LT1's making up to 1,100+HP, running high spring pressure solid roller cams.... it should prove more than adequate for most of us
Old May 25, 2004 | 09:49 PM
camaro325's Avatar
how much horsepower can the LT4 timing cain with sprokets handle, and is it a direct fit with no customizations ??
Old May 29, 2004 | 08:44 PM
"White Knight"'s Avatar
Look at Injuneers post above^
Old May 29, 2004 | 09:05 PM
Robs97Z28's Avatar
up 1,100 HP!! I'd say that is good enough for me...
Old May 30, 2004 | 01:48 PM
camaro325's Avatar
ohh sorry, I thought there was a difference between the LT4 and LT4 extreme duty
Old May 30, 2004 | 02:23 PM
Don 97 SS's Avatar
There is a difference between those sets. The GM LT1/LT4 Ed timing set that Fred mentions is much better/durable than the basic GM LT4 timing set, particularly considering the small price difference.
Old Jun 1, 2004 | 12:16 AM
camaro325's Avatar
oh thank's where is a good place to buy the lt4 extreme duty kit, and about how much
Old Jun 1, 2004 | 12:24 AM
CrAkD X 95TA's Avatar
its $250 from jegs, $300 from thunder racing......dal wants around $240 for it i havent called jason yet im planning on ordering it soon.
Old Jun 1, 2004 | 04:32 AM
95Z-Cross-Eyed's Avatar
I have one for sale in the used car parts section for 150 plus shipping.
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
