Comp Cams XE 224/230 Cam
Old May 31, 2004 | 10:58 PM
stonecoldz's Avatar
Question Comp Cams XE 224/230 Cam
hey guys,
I bought the xe 224/230 cam kit back in march. I haven't installed it yet, probably won't till august or winter. My question is, i'm not sure if this is the right cam. I just looked at the specs on the box, and these numbers are different than the one i thought i was getting. I'll give you the specs and you guys tell me if this is the right cam.
07-000-8
LT1 3315/3315 114 LSA(GOT 114 FOR EMISSIONS IN ILLINOIS)
CAM SPECS--------INT EXH
ADV DUR: 281 281
DUR @ .050 230 230 LOPE SEP:114
VALVE LIFT: .050 .510 .510
does this help any???????
this is what i bought with it:
Comp Cams Pro-Magnum Rocker Arms ( 1.6 self aligning)
EX Components 612 Valve Srings
EX Components 138 Ultra Light Weight Chromoly Retainers
EX Components 391 Hardened Valve Locks
EX Components 720H Hardened Pushrods
I told them i drive it on the street and might go to the track once or twice a year. Does these specs sound like the right one? i saw some #'s like .544 lift or something like that.
thanks for your help.
Old May 31, 2004 | 11:44 PM
ZDriver96's Avatar
Y not call comp and ask them?
.544 lift is right i believe. I had the 220/230 cam which was pretty similar but reved alittle higher. Have to see if the lift was shown with 1.6rr or 1.5(stock).
Old Jun 1, 2004 | 12:25 AM
stonecoldz's Avatar
anybody else know if that is with 1.5 or 1.6 rr???
Old Jun 1, 2004 | 12:27 AM
ZDriver96's Avatar
if it is a 224/230 it'd be .544 on 1.6 rockers
Old Jun 1, 2004 | 01:12 AM
QCKZ28's Avatar
the xe224/230 came in different versions that varied in lift....
where did you buy it from?
Old Jun 1, 2004 | 01:21 AM
SStrokerAce's Avatar
If this is what the cam card said......
07-000-8
ADV DUR: 281 281
Then no
That is a cast core (looks a lot like the stock one)
230/230 cam with a 114
That is not a 224/230
Sorry to tell ya but that's not what you thought it was.
Bret
Old Jun 1, 2004 | 06:11 AM
stonecoldz's Avatar
i got it from combo motorsports
rojo10956
Classic Engine Tech
Dec 13, 2021 12:17 PM
oldschool
Feb 9, 2016 09:21 PM
MadMav
May 25, 2015 09:35 PM
racecarz28
Mar 30, 2015 09:55 PM
alliance12364
Mar 6, 2015 04:39 PM
