Timing Belt Question?
Old Nov 19, 2008 | 12:50 PM
LT1CST's Avatar
Gotta 94 LT1 and my damn Timing belt likes to slid off my crank. I have allready placed thread locker on the hub bolt to make sure the hub doesnt slide off. Can anyone recomend any ways to keep my timing belt on. It likes to slide off the hub.
Chris
Old Nov 19, 2008 | 01:00 PM
camarobird92's Avatar
Your timing belt? Lt1's have a timing chain. Are you talking about the accessory belt that runs the alt., power steering, A/C, etc?
Old Nov 19, 2008 | 01:48 PM
Black_95Formula's Avatar
If your hub is slipping, then you need to get it keyed. But, that shouldn't happen unless you're running a high-PSI supercharger...
If your accessory belt is slipping, then you need to check it for oil or coolant, and if it's clean, then start looking at the pullies to make sure they're all aligned properly.
Old Nov 19, 2008 | 03:44 PM
LT1CST's Avatar
Yes I was reffering to the Accesorry Belt sorry
Chris
Old Nov 19, 2008 | 04:24 PM
BUBBA's Avatar
Make sure your belt is good. Make sure pulleys are aligned---you can use a straight edge to determine alignment. Make sure your idler pulley (the one that doesn't run anything but keeps tension on the serpentine belt) is tight and not really chewed up, in case a replacement might be in order.
Shouldn't throw belts if right belt and everything else is ok. JMHO
Old Nov 19, 2008 | 06:45 PM
LaredoZ28's Avatar
I agree 100%.
Old Nov 20, 2008 | 05:17 AM
Have you checked the damper to make sure the rubber ring that holds the inner and outer steel rings together isn't cracked, allowing the pulley to wobble?
Old Nov 20, 2008 | 05:58 AM
David94TA's Avatar
Also check the bolt holding the hub onto the crankshaft. Hard to believe, but I had that work loose at one time and I was having the same problem you are with the belt.
RUDEDOG
Parts Wanted
Apr 24, 2015 09:47 PM
siguy
Nov 27, 2014 10:07 AM
Snoman73
Nov 17, 2014 07:22 PM
1LEThumper
Jul 14, 2003 12:45 PM
