Time to tune up?
Old Dec 12, 2007 | 11:14 AM
dandan111's Avatar
Time to tune up?
My T/A is a 1995 with 33,000 miles.
I added lucas oil treatment at the last
oil change.
The car runs great but does tend to run
a little higher rpm before shifting than I like.
Should I start thinking about a transmission
filter-fluid change? what brand?
Should the radiator be flushed and changed
too?
rear end?
Im thinking at 12 years I should maybe give
it some TLC.
The org. tires are getting hard as plastic..
Maybe some new BFGs in the spring
Old Dec 12, 2007 | 12:29 PM
Regular maintenance is something everyone should do. You certainly are not going to hurt anything. Though, I don't know why anyone uses oil additives. A well maintained engine should never need anything but oil, IMO.
Old Dec 12, 2007 | 10:04 PM
dandan111's Avatar
I have heard of LT1s needing rebuilt that
have low miles 50-60,000 and the oil treatment
should give extra protection, (I dont know if its
true but I bought it)!!
What should I focus on next, transmission,rear end,
radiator?
-The coolent looks clean and the car never gets too hot.
-The rear end seems fine, posi works well.
-Transmission worries me, it revs into red line(not sure of rpm)
before shifting from 1st to 2nd. Im always thinking I should
let off of the pedal so it can shift. Maybe its fine, if I had
better tires I may not notice it so much. I get a little
tire spin when it shifts.(I open it up from time to time).
Old Dec 13, 2007 | 06:50 PM
96capricemgr's Avatar
Lucas is BAD BAD stuff.
I am sure LT1s have needed repair at 50-60K miles but neglect or abuse are most likely the cause not routine wear. A lot of guys running well over 100K on modded LT1s, my wagon has 221K on it and has recently been to the east coast and back without a hitch.
DirtyDaveW
Dec 1, 2016 05:37 PM
InfernalVortex
Jan 17, 2015 09:35 AM
Jazsun
Dec 29, 2014 12:14 PM
