time for more power but where to start
Old Nov 18, 2010 | 09:38 PM
thegeovonn's Avatar
I have a 96 camaro lt1 all that has been done is a cold air intake under drivepulleys flowmaster muffler what more can I do to get more power need help
Old Nov 18, 2010 | 11:27 PM
Re: time for more power but where to start
What's your budget? You can replace the Flowmaster muffler with a full cat-back exhaust. Do the throttle body coolant bypass for 6HP. Install a set of 1.6X roller rockers. Do a set of long tube headers. PCM tune and a 160-degF thermostat. Upgrade the camshaft, with matching valve train parts. Have your stock heads ported. Bore it and stroke it to 383 or 396 cubic inches. Blower, turbo or nitrous.......
Really no limit to what you can do, other than how much you have to spend. Figure whatever you put into the engine, plan on spending at least 1/2 additional for drivetrain and suspension mods.
For starters.... provide more info about your car - which trans, A4 of M6? If its the A4, which rear gears - 2.73 or 3.23?
Old Nov 19, 2010 | 05:13 AM
rskrause's Avatar
Moderator
Definitely more info needed, including some idea of the budget. The sky is the limit, so you need to provide as much info as you can. There is a lot of experience with the "outmoded" LT platform here, but a very general question may not generate much response.
Rich
Old Nov 19, 2010 | 10:28 AM
thegeovonn's Avatar
well my bubget is $3,000 and I was looking to get an cat-back an cam and get the heads done and I also have the A4 with 3.23 gears not tryin to go too crazy like to keep it as an daily driver
Old Nov 19, 2010 | 10:37 AM
thegeovonn's Avatar
Rich
well my budget is $3,000 I will like to get more power but also keep it as an daily driver and it also has A4 with 3.23 gears also will like to know what would be a good cat-back and headers to go on
Old Nov 20, 2010 | 01:24 PM
foxbat's Avatar
cat back is really dependent on personal choice (sound mostly). all will give about 10 whp. stainless steel brands like corsa, borla, bb triflow will be 500-700 but last forever. for headers, decide of you want to keep emissions/cat etc. if you do, you can't beat mac-mids, if you don't need cats and emissions and you're ok with low ground clearance, get long tubes. be sure to get any header ceramic coated!
Old Nov 22, 2010 | 01:23 AM
thegeovonn's Avatar
Hay Thanks Alot For That Info I Think I'LL Be Going With Some Long Tubes
Old Nov 22, 2010 | 01:28 AM
Klypto's Avatar
i love my hookers
Old Nov 22, 2010 | 01:38 AM
thegeovonn's Avatar
i was looking at the hookers or the pace setters
Old Nov 22, 2010 | 11:06 AM
David94TA's Avatar
I have Kooks long tubes with catted Y-pipe and pass emissions easily. The Kooks gave me quite a bit more ground clearance than my Hookers. They are pricey, especially coated. But as someone else mentioned, definitely have them coated no matter what brand. I didn't when I first put my Kooks in and they kept the engine bay extremely hot and looked bad after a while.
Old Nov 22, 2010 | 02:12 PM
henryz28's Avatar
I would do the headers, stall, and cam then a mail order tune. Depending on who is doing the work you might go over budget.
Old Nov 22, 2010 | 11:30 PM
thegeovonn's Avatar
hay thanks for all the replys i'm going to take a look at thoes kooks you say it gives you more ground clearance and what would be a good stall i heard the yank was a good one
Old Nov 23, 2010 | 11:14 PM
henryz28's Avatar
Yank is a good stall. I know Edge builds good converters; I talked to the owner; great guy he drives a srt8 challenger that he bought from a Dodge dealer my aunt manages.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
Dec 1, 2014 08:08 AM
