Tightening the banjo bolts in back of the heads.
Old Sep 22, 2006 | 02:40 PM
  #16
wrd1972's Avatar
Re: Tightening the banjo bolts in back of the heads.
Originally Posted by anaik
Compliments of shoebox.
1993-1994 steam pipe behind heads, incl bolts, seals and hose to radiator 10108635 $31.14
1995-1997 steam pipe behind heads, incl bolts and seals 12556260 $24.91
1993-1997 coolant steam pipe seals 10108689 $3.00
1993-1997 coolant steam pipe bolts 12552974 $3.07
__________________
Thanks.
But it appears that #12 is an o-ring and #30 is a seal.
Do you use an o-ring and a seal on each side or do you use just two seals?
Old Sep 22, 2006 | 03:00 PM
  #17
Javier97Z28's Avatar
Moderator
Originally Posted by Eddie Z-28
I didn't think so. All I need to do is tighten the one down on the passenger side. Do any of you think that the seals might be bad? They're brand new.
Oh, didn't see that part. As mentioned, as long as you didn't cross thread (check around the washer to make sure it's flat with your fingernail...) you shouldn't need new seals.
Just snug it up some and see what happens.
Old Sep 22, 2006 | 03:03 PM
  #18
Chevycobb's Avatar
yeah if the seals are new then they won't be the problem. when they went in did they seem hard to turn or did they go in easily
Old Sep 22, 2006 | 03:12 PM
  #19
DirtyDaveW's Avatar
I replaced mine on my '94 last month. Like Javier said, just get one of those combo 15m ratcheting wrenches and make sure they're tight first. If it continues to leak, try the washers. I did the complete swap from the old steam pipe/washer/hose assembly to a brand new one with the engine in place. Just reach back there and you'll find room with the ratchet wrench.
Old Sep 22, 2006 | 03:18 PM
  #20
Originally Posted by wrd1972
I will be needing the correct washers and such for when I remove the heads this winter.
Looking at the diagram, what is the diffrence between #12 & #30?
What is the difference in the bolts #31 & 32?
Does anyone have the part numbers for all these parts:
12
30
31
32
Thanks.
12 and 30 are the same and 31 and 32 are the same. You will need 4 seals and two bolts.
Old Sep 22, 2006 | 03:23 PM
  #21
wrd1972's Avatar
It all makes sense now. Thanks
Old Sep 22, 2006 | 04:28 PM
  #22
Cman's Avatar
Get a mechanics mirror so you can at least see where it is on the head and do'er.
Pulling the engine to do a couple of bolts at the back of the heads, that's F-ing hilarious!!!!! That's better than people a few years ago saying to pull your exhaust off to do plugs...........right!!!!
Tony
Old Sep 22, 2006 | 06:47 PM
  #23
davidarel's Avatar
Wow, do I detect a hint of carcasm? Dropping the cradle might not be totally necessary but it takes all of maybe two hours to do.
95chwagon
Feb 28, 2015 12:02 PM
MadMav
Feb 6, 2015 11:02 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
ddr698
Jan 9, 2015 10:05 AM
Jazsun
Dec 29, 2014 12:14 PM
