Tig welding on waterpump??
Old Jun 26, 2007 | 11:41 PM
  #16
thesoundandthefury's Avatar
Originally Posted by T/A KID
thesoundandthefury
I noticed you plugged the coolant sensor in the waterpump??
What is your thought on that??
I got the idea from this:
http://www.carolinarodshop.com/miscserv.htm
You can't see it from that angle in the above pic, but I drilled and tapped a new hole for a 1/2" NPT pipe bushing on the bottom of the pump. The coolant temp sensor and wire will be hidden when viewing the engine from the installed vantage point.
Details that help win show trophies.
Old Jun 27, 2007 | 12:12 AM
  #17
T/A KID's Avatar
I got to remember your a show car type of guy, lol. Looks neat, never seen it done before.
Old Jun 27, 2007 | 12:28 AM
  #18
tapout911's Avatar
Glad you posted this Ben. I was leary of the welding. I had thought of tapping it like Mdacton. Looks like a good way to go.
Old Jun 29, 2007 | 12:46 AM
  #19
tapout911's Avatar
Did mine tonight while at work. I did exactly what Mdacton said and it worked great. Tap used was 1/2-14 and plugged it with a 1/2 pipe thread plug.
Old Aug 24, 2007 | 09:45 PM
  #20
tagz's Avatar
you said u tapped it with a 1/2 -14... doesn't it have to be a special tap for NPT
Old Aug 24, 2007 | 10:06 PM
  #21
Boosted_Z28's Avatar
"Pipe" threads are tapered, so as long as the tap you use is a 1/2"-14tpi NPT, it will work just fine.
Old Aug 24, 2007 | 10:09 PM
  #22
tagz's Avatar
where do u guys buy the npt taps, i have one machinery type shop that MIGHT have them... but as far aas like sears or home depot, definatly not a stocked item.
Old Aug 25, 2007 | 07:10 AM
  #23
mdacton's Avatar
plumbing supply place should have them, I will just go to the machine shop if I don't have one and tell them what I need. They never charge me and I will cut the threads myself while i'm there
Old Aug 25, 2007 | 11:49 AM
  #24
T/A KID's Avatar
I actually ended up having mine Tig welded and it look awsome, since then I have had a -16 and -20 welded onto the waterpump and I am running braided line to my griffin rad. Looks SWEET
Old Aug 25, 2007 | 12:54 PM
  #25
lethal93ta's Avatar
Im putting 2 -20 fittings on mine and runnign braided lines to my griffen
Old Sep 1, 2007 | 01:29 PM
  #26
ZBLKHELLRZR's Avatar
Where are you guys getting the 3/4" brass freeze plugs from?
Old Sep 1, 2007 | 03:47 PM
  #27
LT-x7's Avatar
I got mine at Kragen, I'd assume most auto parts stores carry them.
football4life
Oct 4, 2015 07:48 AM
reww86
Aug 29, 2015 06:04 PM
4586
Aug 22, 2015 01:09 AM
4586
Aug 18, 2015 07:08 AM
