Tie Rod install problem.
Old Mar 14, 2004 | 07:35 PM
ledfootz28's Avatar
me and a buddy were installing the front tie rods,the pass side went on fine but the drivers side is what stumped us..we put vice grips on the nut the used pliars on the tie rod to try and take it off,it worked on the other side.but the nut got loose and started moving toward the back and the tie rod isnt loosening.any ideas on what to do?
Old Mar 14, 2004 | 07:57 PM
kmook's Avatar
Advanced Tech Moderator
General engine/suspension/etc troubleshooting should be posted in a generation spacific forum.
Transfering to LT1 Tech, thank you.
Old Mar 14, 2004 | 08:00 PM
HBHRacing's Avatar
leave the tie rod end connected to the spindle to hold it from there, use vice grips on the tie rod and the wrench on the nut. you might have to heat it if you can not get it like that
Old Mar 14, 2004 | 08:10 PM
ledfootz28's Avatar
yea harlan thats what we tried doin,im thinking heating it might work.any other ideas?
Old Mar 14, 2004 | 08:16 PM
HBHRacing's Avatar
You can try some penitrent lube first. let it sit and try it. you can try and wedge siomething against the vice grips so it doesn;t move alowing you to use all your force to hit the wrench. you don;t wanna push the wrench you want to hit it quickly and hard or hit it with a hammer. if none of that workes... heat it and srpay it with lube while hot
Old Mar 14, 2004 | 08:22 PM
ledfootz28's Avatar
alright i ll try that and let ya know how it goes.thanks
Old Mar 14, 2004 | 09:02 PM
atljar's Avatar
I had trouble with one of mine too, and it hadnt really been on there that long. Heated it up and it came off in 1/2 second.
Old Mar 14, 2004 | 09:45 PM
ledfootz28's Avatar
what did u heat it up with?
Old Mar 14, 2004 | 09:46 PM
HBHRacing's Avatar
even a burns-O-Matic torch would work unless you got something bigger. once it;s hot shock it with the cool spray lube and the lube will "suck" into the threads
Old Mar 14, 2004 | 10:21 PM
atljar's Avatar
Just a propane torch.
I wouldnt shock it with any liquid. Sudden heat changes in metal will stress it and cause it to become brittle. NOt to mention, many penetrants are flammable
Old Mar 14, 2004 | 11:00 PM
HBHRacing's Avatar
it's not gonna cool it fast enough to crack the metal or harm the integrety.. and I have never seen any ignite unless it was with an open flame. just hiting the nut that you heated will caus e alot of smoke but no flame. and a shock from hot to cool is what you want cause it will cause the theards to expend then contract breaking it lose.. the same thing is done with torchs and a water hose..
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Richardan15
May 30, 2015 08:36 AM
Hurin
Dec 13, 2014 07:38 PM
