Help! asap..engine oil temp sensor
Old Mar 14, 2004 | 08:37 PM
Jeremy_30th's Avatar
Exclamation Help! asap..engine oil temp sensor
Where is it ? so I can replace it. I did a search and checked the shoebox's site and nothing...I'm reading -34* on autotap..can this cause any probs
Old Mar 14, 2004 | 09:00 PM
Dave89IROC's Avatar
I didn't know there was an oil temp sender??
Old Mar 14, 2004 | 09:05 PM
25thBird's Avatar
i don't know of an oil temp sensor, i do know about an oil pressure sensor though. It might differ from an LS1, but the LS1 has it behind the intake manifold and it looks like a small black tube. You gotta remove the IM to see it. Like I said... LT1 might be on a different location though. Hope that's what you were looking for.
Old Mar 14, 2004 | 09:10 PM
thanks for the replies guys..and yeah I thinking like you I know of the low level sensor in the pan and the press sensor on the back of intake but oil temp sensor I have never heard of it.. but the autotap has it listed in my supported parameters and its reading -34 deg . under info it says its used to control cooling fans but thats what the coolant sensor does
Old Mar 14, 2004 | 09:17 PM
JSK333's Avatar
There isn't one on F-Bodies even though the PCM has provisions for it.
The Vette has it, though.
Old Mar 14, 2004 | 09:27 PM
Thanks, I was getting worried for nothing..the shouldn't put that stuff in there if its bogus
Old Mar 14, 2004 | 11:05 PM
If I find one, I will be sure to get a picture of it.
HectorM52
Jul 30, 2017 11:46 AM
Magenta_Hearts
Mar 29, 2017 08:54 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
