Ticking, tapping, clacking??
Old Sep 3, 2003 | 07:55 PM
naaz90's Avatar
I've had some ticking now for a few months. Ive noticed that at idle the ticking is only present every five seconds. It will tick for 3 seconds then stop for 5 and cycle again. This is only at idle. Once i hit the gas and bring it to any rpm above idle the ticking becomes constant. I've thought maybe a bad lifter or possibly a bent pushrod.
Your thoughts are welcome
Old Sep 3, 2003 | 11:38 PM
Bud M's Avatar
Although I won't try to offer any explanation why it might be intermittent, I will suggest that you make sure your spark plugs are tight. A loose plug will make a ticking sound and if left alone will cause serious damage to the threads in the spark plug hole. Better safe than sorry!
Old Sep 4, 2003 | 12:15 AM
Dolby109's Avatar
Just curious, hows your oil pressure look?
Old Sep 4, 2003 | 12:38 AM
96redformula7's Avatar
Cool
I just had a problem similar to that and after months of guessing I figured it out today. CHECK TO MAKE SURE ALL YOUR SPARK PLUGS ARE TIGHT!
Old Sep 4, 2003 | 11:27 AM
naaz90's Avatar
Oil pressure is good, spark plugs are good.
surreybrad
Sep 29, 2015 09:00 PM
1slow93z28
Sep 1, 2015 06:22 PM
FryedClutch
Sep 1, 2015 08:24 AM
94Z28LS1toLT1
Apr 30, 2015 05:19 PM
importkiller94
Jan 17, 2015 09:03 PM
