Had a loose Spark Plug~Could it have cause any damage?
Old Sep 3, 2003 | 11:34 PM
96redformula7's Avatar
The plug was the first plug on the driver's side. I do not know how long it has been losse for but It was really losse and could be tightened or loosened by hand. I tightened it up with a ratchet and I felt an immediate horsepower gain after. Is their any chances I could have damaged something or a result of it?
Old Sep 3, 2003 | 11:41 PM
94formulabz's Avatar
well the threads aren't damaged if you could thread it by hand. And since it wasn't all the way out nothing to in there. Other than maybe the sparkplug itself possibly being fouled from the poor combustion I wouldn't sweat it. Glad you found the problem and it was a free fix!
-Brent
Old Sep 4, 2003 | 08:10 AM
93transam1234's Avatar
smae
I had the same problem with 2 of my plugs tho...Lot of diffrence when i got those boys in tight ...also one of them keeps loosing up on me so make sure u check it agin...
Old Sep 4, 2003 | 11:34 AM
Hyperspeed97z28's Avatar
I had one go loose on me... couldnt tell power wise though, I looked under a few days after the header install, tighten the bolts again and such and when I started her, I seen that one rattling loose a lil.... no problems since though....
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
blkWidow
May 3, 2015 08:42 AM
nikko
Apr 20, 2015 07:56 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
