Ticking sound? What is it?
Old May 24, 2003 | 03:10 AM
Xride's Avatar
I have a ticking sound coming from the drivers side of the engine, its not really loud, but noticable and really light at the same time.
This started after my oil change.
Old May 24, 2003 | 03:56 AM
96redformula7's Avatar
check this out
Mine is probably doing the same thing as yours. Check out the video I made of it and tell me if it sounds the same.
http://web.camaross.com/forums/showt...hreadid=123566
Old May 24, 2003 | 03:58 AM
IllusionalTA's Avatar
possibly a exhaust leak.. or a rocker.. .. Could be both.. usually the only tickers on the motor ..
Old May 24, 2003 | 03:59 AM
Zerosheaven's Avatar
fuel injectors maybe??
Old May 24, 2003 | 04:08 AM
Thanks all. I have been told that it sounds exatly like an exhaust leak and i am prolly gonna check that route first. Check to make sure all the manifold bolt are on tight. Thank you all again
Old May 24, 2003 | 11:51 AM
Fastbird93's Avatar
There is also a possibility of the tick being from a lifter.
Old May 24, 2003 | 01:19 PM
Xride's Avatar
How do I tell, or fix it?
how do I cheak for the injectors as well?
I tried to look for an exhaust leak by blowing this fog like smoke stuff from a can into the engine bay and it stayed pretty calm no vortex' from moving air, but I have no idea how to check for an exhaust leak, all the bolts appeared to be tight.
thanks for the ideas, if nothing else this might give me a reason to get headers and RR's
Old May 24, 2003 | 01:34 PM
My95Z's Avatar
it is probably injectors..the lt1 injectors are louder than most cars
Old May 24, 2003 | 01:53 PM
ibanez6rg's Avatar
Use a screwdriver
Old May 24, 2003 | 01:56 PM
Xride's Avatar
Originally posted by ibanez6rg
Use a screwdriver
I'm still kinda new to this, changed my own oil for the first time yesterday.
Old May 24, 2003 | 10:25 PM
Bud M's Avatar
Make sure your spark plugs are all tight.
Old May 25, 2003 | 09:55 AM
ibanez6rg's Avatar
Use a screwdriver to put up to things that you think are making the noise and put your ear at the other end. Sort of an old trick
94Maroz28
Oct 27, 2015 04:38 PM
PopoFormula
Oct 12, 2015 04:19 PM
4586
Sep 27, 2015 01:55 PM
autoxr166
Sep 25, 2015 04:21 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
