ticking sound
Old May 1, 2006 | 12:50 PM
Formula594's Avatar
ticking sound
Yesterday, I installed new AC Delco plugs and MSD 8.5mm wires on my 94 Formula.Before the installation I would hear a real low ticking sound but now after the tune up I'm not sure if it's the same ticking sound but if it is, it got like twenty times louder.I drove my car after I finished and that ticking sound is loud upon acceeleration.I also have Comp Cams 1.5 roller rockers,could they possibly be loose.Another thing,when you install the y-pipe to the manifolds should there be any space between them,because I left some space between them after tightening them.I would really appreciate any help and suggestions.
Old May 1, 2006 | 02:10 PM
fyacamaroz2895's Avatar
Re: ticking sound
sounds like a loose plug man check em should be a lil more than hand tight
Old May 1, 2006 | 02:38 PM
OBE1 95Z28's Avatar
Re: ticking sound
If the ticking is coming from arcing of the ignition, you'll be able to see it in the dark (hood open, engine running).
Old May 1, 2006 | 04:09 PM
Formula594's Avatar
Cool Re: ticking sound
Just figured out the problem,my y pipe was loose.Thanks for the replies guys. http://web.camaross.com/forums/images/icons/icon7.gif
94Maroz28
Oct 27, 2015 04:38 PM
PopoFormula
Oct 12, 2015 04:19 PM
4586
Sep 27, 2015 01:55 PM
autoxr166
Sep 25, 2015 04:21 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
