Ticking noise in front of engine
Old Nov 25, 2004 | 09:54 AM
Zjoker's Avatar
Question Ticking noise in front of engine
Just what the tread says. I have a ticking noise coming from the front of the engine almost right on top the water pump. I have check the valve train no bent push rods and the rockers adjust properly. This problem also causes a miss in the engine. I know this is the advance problem area; but nobody else has been able to provide a solution with tearing the engine down. It is a 396 with 4 bolt, built just over a year ago. HELP
Old Nov 25, 2004 | 11:34 PM
Re: Ticking noise in front of engine
Moving to "LT1 Engine Tech".
Old Nov 28, 2004 | 10:20 AM
Zjoker's Avatar
Anybody got any Ideas?
Old Nov 28, 2004 | 10:27 AM
94zgreenmachine's Avatar
Exhaust leak. PITA to tighten the bolt under the alternator. Possible intake leak up front.
Old Nov 28, 2004 | 10:57 AM
FryedClutch's Avatar
agreed sounds like exhaust leak to me
Old Nov 28, 2004 | 11:16 AM
99Bird's Avatar
Is the noise RPM dependent? Is it a crisp metalic like ticking? If so sounds like an exhaust leak to me too... check your spark plugs and header bolts. Did you delete the egr?
Old Nov 28, 2004 | 11:22 AM
pearlpurple's Avatar
Check your plugs wires at your Opti, maybe one is arcing out as sometimes arcing out can be kinda loud and would definitly cause a miss.
Exhaust leak may it also be
Old Nov 28, 2004 | 11:28 AM
99Bird's Avatar
Good call on that....
Old Nov 29, 2004 | 07:25 PM
Zjoker's Avatar
Check wires around opti, repalced coil with accel set up, egr still in system?
importkiller94
Jan 17, 2015 09:03 PM
Jazsun
Dec 29, 2014 12:14 PM
siguy
Nov 27, 2014 10:07 AM
squarehead
Nov 21, 2014 08:02 PM
