Ticking Noise
Old Sep 19, 2008 | 12:32 AM
lightskindwonder's Avatar
Ticking Noise
After doing some freeway racing....i noticed my car starts to make a slight ticking noise when i step on the gas (I can hear it in higher gears...not so much in 1st & 2nd...probably because my exhaust is too loud. at idle, or at highway cruising speeds, the ticking isn't there...or at least i don't hear it. it seems to come with the acceleration. Anyway...i haven't taken off the valve covers yet. Do you guys think it could be a slight exhaust leak at the heads to header surface, or bent valves or pushrods? The car seems to be running completely fine with the same power as before....just the ticking. I've checked the oil level and pressure, both are fine. The car does not run hot or missfire. Anyone with a similar experience or ideas?
Old Sep 19, 2008 | 09:50 AM
stvski80085's Avatar
I would say check the exhuast for sure.
Old Sep 19, 2008 | 09:51 AM
pizzi-man's Avatar
more then likely an exhaust leak
autoxr166
Sep 25, 2015 04:21 PM
rideordie
Sep 7, 2015 08:22 AM
1slow93z28
Sep 1, 2015 06:22 PM
colts0455
13
Aug 7, 2015 09:15 PM
colts0455
Jul 7, 2015 07:19 PM
