ticking noise
Old Sep 4, 2006 | 02:03 PM
94blk-lt1's Avatar
ticking noise
i have heard a ticking noise in the front drivers side for quite a while now since i got my 94 z. i never really paid any attention to it though becase it would go away as the car warmed up. now i notice that the ticking noise is getting slightly louder; but still goes away after it warms up. i want to try to takle the noise before it becomes a major problem. what could the ticking noise be and how could i fix it?? i was thinking it might be a bent pushrod....but i am not sure. any help/suggestions on how to fix? thanks.
Old Sep 4, 2006 | 04:02 PM
sscott's Avatar
Re: ticking noise
That ticking noise you are hearing is probably your fuel injectors, they have ball bearings in them that can sound loud at times, completely normal. Does your car run crappy, if not it's likely your injectors.
Old Sep 4, 2006 | 04:11 PM
94blk-lt1's Avatar
Re: ticking noise
no, i do not think it is an injector....i replaced them about 4 months ago. the car runs fine, engine very strong.
Old Sep 4, 2006 | 04:38 PM
fbodyboy's Avatar
Re: ticking noise
It might be exhaust gaskets, they have a tendency to make a ticking noise on startup but when the engine warms up it goes away. Over time it gets louder and louder then eventually wont go away even when the engine warms up. Its not that big of a deal though, its more annoying then anything else. It also might be the lifters, when they get loose they can cause a ticking noise. Its not too common because the lifters are supposed to compensate for some looseness but it does happen. Happen to mine and after i reajusted the lifters the ticking went away, but then ironically my header gaskets started ticking . Oh well just a reason to replace the shorties with longtubes
autoxr166
Sep 25, 2015 04:21 PM
rideordie
Sep 7, 2015 08:22 AM
1slow93z28
Sep 1, 2015 06:22 PM
colts0455
13
Aug 7, 2015 09:15 PM
colts0455
Jul 7, 2015 07:19 PM
